GChuck
Jan 29, 2024Aspirant
Get routers MAC addresses
I there any way within the Netgear Router web app to get the MAC addresses of the WAN, LAN and the three WLAN ports. I've been using Linksys devices for years and this information was always availab...
Jan 29, 2024Guru - Experienced User
MAC addresses should be see on the routers web page under Advanced tab.
- GChuckJan 30, 2024Aspirant
Thanks.
I was hoping to be able to see ALL the interface MAC addresses. I can see the WAN and LAN and the 2.4GHz wifi network, but cannot see the addresses for the 5GHz and 6GHz networks.
My old Dlink 868L Wireless AC router just listed each network with associated addresses (*MAC and ethernet).
I think I've figured them out by using Inssider.
Greg
- michaelkenwardJan 30, 2024Guru - Experienced User
Attached devices?
In the Basic menu for your device.
If you see just an IP address and image, click the device.
Among other ways.
- FURRYe38Jan 30, 2024Guru - Experienced User
Checking mine, MAC addresses are not displayed in the WEB UI for the 5 and 6 Ghz radios. Maybe that something NG didn't intend or left out. Same is seen on my RAX120 as well.
I was able to see the 5Ghz MAC address in a wifi analyzer though.
GChuck wrote:
Thanks.
Greg
- KitsapJan 30, 2024Master
In a web browser, append /hidden_info.htm to the IP address you use to log in to the router user interface.
As an example, http://192.168.1.1/hidden_info.htm The IP address of your router may be different.
This may not work for newer generation routers.
