DJSammit
Dec 01, 2019Aspirant
Getting "It's wrong operation" Error when port forwarding on RAX35
I chose the model as RAX40 because the filter can't find my actual router number which is RAX35 (My issue aside, this is a little concerning that the Netgear forums can't find my router?) Anyways...
Christian_R
Dec 03, 2019NETGEAR Employee Retired
Hi DJSammit,
Would you mind providing the web browser you're using and if you can try another web browser and let me know if the issue persists.
Thanks,
Christian
- DJSammitDec 04, 2019Aspirant
Hi Christian,
I should've thought of this.... Although I was just using port forwarding on a different netgear router on the same computer with the same browser and had no issues. I'm confused why that would cause an error on only the port forwarding settings but none of the other ones.
Anyway, I was using Chrome (which still does not work) but when I switched to Edge I was able to update with the proper settings.
Thanks again,
Sam
- Christian_RDec 05, 2019NETGEAR Employee Retired
Hi Sam,
Thanks for the update and glad you got it working!Have a good day!
Christian
