Duhhstin
Jan 03, 2022Aspirant
Getting random ping spikes
I just got a AX6000 WiFi Cable Modem Router (CAX80) yesterday and have been getting constant ping spikes in games and such every 30-45 seconds ever since. I am running on firmware v2.1.3.5. I replace...
Jan 03, 2022Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Netgear has set up a community forum specifically for the Cable Modem products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
