carnalimr
Mar 23, 2020Aspirant
Getting the most out of WiFi 6
Hello, So I've had the Nighthawk AX4: RAX40 for a while now. I finally added a WiFi 6 card to my desktop that's about 30 feet away from my router. I am getting about additional 100mbpsDL and 50mbps ...
Christian_R
Mar 25, 2020NETGEAR Employee Retired
Hello carnalimr,
Can you confirm whether your desktop is hardwired to your router? If it's wireless, can you confirm whether its connecting to the 2.4 or 5GHz band.
Thanks,
Christian
- carnalimrMar 25, 2020Aspirant
It is not hardwired. It is also on the 5ghz band.
- Christian_RMar 27, 2020NETGEAR Employee Retired
Hi carnalimr,
Thanks for confirming. May you try changing the channel on the 5GHz band to see if there are any improvements.
Thanks,
Christian
