Elie973
Dec 30, 2020Aspirant
GHz 2 wifi completely disappeared since 1.0.3.106_1.0.58 version
I everybody i just installed the new 1.0.3.106_1.0.58 version and my 5GHz 2 wifi just disappeared, impossible to make it back even after a factory reset.
Dec 30, 2020Guru - Experienced User
what router do you have?
You didn't put a model number.
What gateway did you connect it to?
- Elie973Dec 30, 2020Aspirant
Sorry here is the infos
NightHawk AX12 RAX200
it's a Livebox 5 connected to it, after 20min the 5GHz 2 reappeared, i decided to reboot the rooter and it's has been appear about a 10min, before the update it hadn't never taken as long as this to apear.
