EW082014
Aug 06, 2024Aspirant
Gig LAN ports only outputting half speed
I recently upgraded my internet package from 500 mbps to 1.2 gbps but it seems my devices on the LAN ports are only receiving about 490-545mbps. Anything connected to the 5 or 6 GHz Wifi see the ful...
Aug 06, 2024Guru - Experienced User
Is this the RAXE500?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
If you have a ISP speed service package now, did you set the RAXE500 for the Multi gig port to use for it's internet connection on the routers web page? Or you still using the yellow 1Gb internet port still?
- EW082014Aug 06, 2024Aspirant
Thanks for the reply!
Yes
>What Firmware version is currently loaded?
V1.2.13.100_2.0.54
>What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Arris SB33 with the multigig port being used as the internet port. Wifi, I can clears speeds 1.3g with the device close to the router
Confirmed, all cables being used where Cat 6. Longest is 25 ft, shortest 10.
- FURRYe38Aug 06, 2024Guru - Experienced User
Sounds like you have the MG port used to connect to the modem if your getting 1.3Gb over wifi which is expected.
You'll not see much over 900Mpbs on the LAN ports due to there max connection rate is 1Gb.
- EW082014Aug 06, 2024AspirantCorrect, the Internet speed isn't the issue, the MG port working as expected. For the 1g LAN ports, all are outputting low 500s, not the low 900 as I was expecting. Are there settings in the router that could be causing this? Thanks
