EW082014
Aug 06, 2024Aspirant
Gig LAN ports only outputting half speed
I recently upgraded my internet package from 500 mbps to 1.2 gbps but it seems my devices on the LAN ports are only receiving about 490-545mbps. Anything connected to the 5 or 6 GHz Wifi see the ful...
EW082014
Aug 07, 2024Aspirant
Got you, SPC is also disabled. I've done further testing and there no change reviewing all of your steps. Thanks
Kitsap
Aug 07, 2024Master
Suggest you check the properties of your network. In Windows, go to Settings -> Network Status and check to see if the network profile is set to Private as opposed to Public. For a home network it should be Private. Sometimes Microsoft updates will arbitrarily change this setting.
If set to Public, Windows throws in a bunch of data barriers under the banner of security.
