tvguylv
Mar 11, 2024Aspirant
Going offline every night
I recently started having the exact same problem. I was using older firmware, and it just started happening. I managed to upgrade to v1.1.3 and that didn't help but it fixed other other problems.
Mar 12, 2024Guru - Experienced User
What model router is this?
Sounds like a factory reset and setup from scratch with out loading a backup configuration from file is needed here.
I now have v1.1.4 installed and I cannot get into my control panel. The router does not go off-line anymore in the middle of the night. I did have to install the latest firmware by directly connecting a computer to the router and doing the install manually.
The system works great. I just can't get into the control panel anymore. It says access denied.
