tvguylv
Mar 11, 2024Aspirant
Going offline every night
I recently started having the exact same problem. I was using older firmware, and it just started happening. I managed to upgrade to v1.1.3 and that didn't help but it fixed other other problems.
tvguylv
Mar 12, 2024Aspirant
its a RAX5400v2... the unit is working but its a brick. I have a lot of IP address I need to re-enter... if I truly need to factory reset the unit. I will throw it in the trash and buy something else if I have to start over.
The firmware screwed me and Netgear want a $99 subscription to fix THEIR problem
Mar 12, 2024Guru - Experienced User
You should have on hand back up configuration files to help avoid wasting time on setting up IF and WHEN factory resets are needed. Which this will be needed.
Good Luck.
