flyingcod
Sep 17, 2024Aspirant
Good wired speed but poor wifi speed - Nighthawk RAX120 AX6000
Hi, RAX120v2 firmware V1.2.9.52 I replaced my old (but reliable) AC1900 R7000 router for a newer RAX120 AX6000 around a year ago. I have two wired connections to my office laptop and son's g...
duhuf
Sep 17, 2024Tutor
Maybe u can try to reset the router then test again
flyingcod
When you say reset, do you mean factory reset?
Thanks
fc
- duhufSep 17, 2024Tutoryes.by the way,have you using dual band in one mode?i suggest u to connect the independent 5g frequency band.because 2.4g/5g band ssid wifi cannot get the fastest wifi speed
- michaelkenwardSep 18, 2024Guru - Experienced User
duhuf wrote:
i suggest u to connect the independent 5g frequency band.because 2.4g/5g band ssid wifi cannot get the fastest wifi speedMy experience is that it depends on the WiFi clients. They go for the "best" signal. If 5 GHz (or even 6 GHz if your router supports it) is strong enough, the client will connect to that.
2.4 GHz is slower but has a longer range, so clients may switch from one to the other as you move around. Most of my 5 GHz kit sticks to that, but I have an MK93 Mesh system.
Devices that are 2.5 GHz only will, of course, just connect to that.
Just another user with time on their hands.
- duhufSep 19, 2024TutorNightawrk mk93 meh system is quite good i also have the same one,but the only problem is, when the mesh system has running a long time,it will be very warm,so do u know how to solve that?
