flyingcod
Sep 17, 2024Aspirant
Good wired speed but poor wifi speed - Nighthawk RAX120 AX6000
Hi, RAX120v2 firmware V1.2.9.52 I replaced my old (but reliable) AC1900 R7000 router for a newer RAX120 AX6000 around a year ago. I have two wired connections to my office laptop and son's g...
michaelkenward
Sep 17, 2024Guru - Experienced User
flyingcod wrote:
Hi,
I replaced my old (but reliable) AC1900 R7000 router for a newer RAX120 AX6000 around a year ago. I have two wired connections to my office laptop and son's gaming rig and these are fine, I get the maximum I pay for with virgin media M250.
I assume that virgin media M250 is the speed you pay for. How does the Internet get to you? What modem.gateway/ONT sits between the world and the RAX120v2?
Am I missing something? Should I turn on QoS? I have changed the 2.4 channels from 1 to 6 to 11 but no luck. Considering going back to the R7000 as I am sure that was faster for wifi.
At those Internet speeds, QoS is best left off.
5 GHz should be faster than 2.4 GHz, especially at close range.
You could put the R7000 into Access Point mode and then plug it into the RAX to see if it really is any faster.
As duhuf suggests, there is no harm a reset.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front. It is also the first thing that Netgear support will recommend.
You could backup our settings before taking the plunge.
Then you can recover if things go pear shaped.
Just another user with time on their hands.
