flyingcod
Sep 17, 2024Aspirant
Good wired speed but poor wifi speed - Nighthawk RAX120 AX6000
Hi, RAX120v2 firmware V1.2.9.52 I replaced my old (but reliable) AC1900 R7000 router for a newer RAX120 AX6000 around a year ago. I have two wired connections to my office laptop and son's g...
flyingcod
When you say reset, do you mean factory reset?
Thanks
fc
duhuf
Sep 17, 2024Tutor
yes.by the way,have you using dual band in one mode?i suggest u to connect the independent 5g frequency band.because 2.4g/5g band ssid wifi cannot get the fastest wifi speed
- michaelkenwardSep 18, 2024Guru - Experienced User
duhuf wrote:
i suggest u to connect the independent 5g frequency band.because 2.4g/5g band ssid wifi cannot get the fastest wifi speedMy experience is that it depends on the WiFi clients. They go for the "best" signal. If 5 GHz (or even 6 GHz if your router supports it) is strong enough, the client will connect to that.
2.4 GHz is slower but has a longer range, so clients may switch from one to the other as you move around. Most of my 5 GHz kit sticks to that, but I have an MK93 Mesh system.
Devices that are 2.5 GHz only will, of course, just connect to that.
Just another user with time on their hands.
- duhufSep 19, 2024TutorNightawrk mk93 meh system is quite good i also have the same one,but the only problem is, when the mesh system has running a long time,it will be very warm,so do u know how to solve that?
- michaelkenwardSep 19, 2024Guru - Experienced User
duhuf wrote:
Nightawrk mk93 meh system is quite good i also have the same one,but the only problem is, when the mesh system has running a long time,it will be very warm,so do u know how to solve that?That is not my experience. My MK93 system is always on and hardly breaks a sweat. I do ensure that the router and satellites have breathing space around them.
