Acts7628
May 08, 2025Follower
Guest Network - Firewall Question
Does the Guest Network have the same security features such as Firewall, DoS & Port Scan Protection, and the Protection Engine like my Main Network has? Thank you. FYI, I have the Nighthawk CAX80 - ...
May 08, 2025Guru - Experienced User
It should. It simply doesn't allow the members on the guest network to access anything on the main network for network segregation/security.
