-SuperMario-
Mar 10, 2024Aspirant
Guest network issues
Greetings community, I am having issues with my guest network. I haven't changed anything in a while and got a complaint today that the guest network is not working. The symptoms are being able ...
- Apr 10, 2024Wanted to update everyone and thank you for helping.
Factory reset resolved the issue.
Kitsap
Mar 10, 2024Master
The symptoms are being able to connect to the ssid but no internet is going through. Everything else is working on the router properly.
I changed the name to a unique name and back to the default and this did not solve the issue.
I'm on the most up-to-date firmware.
Any help would be greatly appreciated.
With your RAX120, have you recently powered down and restarted your local network? What is the brand name and model number of your upstream device between the RAX120 and the internet?
There is a sequence for powering up a local network.
Start with the power buttons off and the power cord disconnected for both your modem/ONT and router. Disconnect the Ethernet cord between the two devices.
Power up your modem/ONT and give it plenty of time to boot and connect to the internet. The device should have an indicator that shows connection to the internet.
Connect the Ethernet cord to your router, connect the power cord, and boot up the router. Give it plenty of time to boot and connect to the internet. The device should have an indicator that shows connection to the internet. Connect your devices and verify access to the internet.
- -SuperMario-Mar 13, 2024AspirantThank you for the reply. I did as you asked and no luck. I am trying to connect something as simple as my phone to my guest network. And it does not work. I have a galaxy Samsung s23 ultra. It connects fine to my main household network. I restarted everything and still no dice.
- FURRYe38Mar 13, 2024Guru - Experienced User
If you set the security to the GN to NONE temporarily. Will the device connect to the network at all?
Re-enable WPA security after testing this. - KitsapMar 13, 2024Master
-SuperMario- wrote:
Thank you for the reply. I did as you asked and no luck. I am trying to connect something as simple as my phone to my guest network. And it does not work. I have a galaxy Samsung s23 ultra. It connects fine to my main household network. I restarted everything and still no dice.On your main Wi-Fi network, do you have smart connect enabled?
Make sure you have smart connect not enabled with separate SSID's for the 2.4 and 5 GHz bands on both your main network and guest network.
- -SuperMario-Mar 15, 2024AspirantI tried both of the solutions and non of them worked unfortunately. 😔
- FURRYe38Mar 21, 2024Guru - Experienced User
Any progress on this?
Is this the only device that has problems on the GN?
-SuperMario- wrote:
Thank you for the reply. I did as you asked and no luck. I am trying to connect something as simple as my phone to my guest network. And it does not work. I have a galaxy Samsung s23 ultra. It connects fine to my main household network. I restarted everything and still no dice.- -SuperMario-Mar 25, 2024AspirantNo, all devices are having this problem. Not just my phone unfortunately.
