-SuperMario-
Mar 10, 2024Aspirant
Guest network issues
Greetings community, I am having issues with my guest network. I haven't changed anything in a while and got a complaint today that the guest network is not working. The symptoms are being able ...
- Apr 10, 2024Wanted to update everyone and thank you for helping.
Factory reset resolved the issue.
-SuperMario-
Mar 13, 2024Aspirant
Thank you for the reply. I did as you asked and no luck. I am trying to connect something as simple as my phone to my guest network. And it does not work. I have a galaxy Samsung s23 ultra. It connects fine to my main household network. I restarted everything and still no dice.
Mar 13, 2024Guru - Experienced User
If you set the security to the GN to NONE temporarily. Will the device connect to the network at all?
Re-enable WPA security after testing this.
