-SuperMario-
Mar 10, 2024Aspirant
Guest network issues
Greetings community, I am having issues with my guest network. I haven't changed anything in a while and got a complaint today that the guest network is not working. The symptoms are being able ...
- Apr 10, 2024Wanted to update everyone and thank you for helping.
Factory reset resolved the issue.
Apr 02, 2024Guru - Experienced User
Any progress on this?
The symptoms are being able to connect to the ssid but no internet is going through. Everything else is working on the router properly.
I changed the name to a unique name and back to the default and this did not solve the issue.
I'm on the most up-to-date firmware.
Any help would be greatly appreciated.
- -SuperMario-Apr 05, 2024AspirantWhen I get home from work I will do a factory reset since I have not done this since last firmware update and will report back.
- -SuperMario-Apr 10, 2024AspirantWanted to update everyone and thank you for helping.
Factory reset resolved the issue.- FURRYe38Apr 10, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
