Tlj86
May 10, 2023Aspirant
Guest network only gives internet when allow devices to see each other
Hello, new on the form.. I’ve done a lot of searching but could not find anything and NG support has not been any help. I really believe I have a bad router. One, when I enabled guest Wi-Fi 2G and 5G...
Tlj86
IPS is Spectrum, Its nighthawk AX1200 AX6000.. Yes the cable from the Modem to the router is fine.. I'm in Infrastructure so I know my way around networking, the device has been updated through Web, I dont use the app.. I plug directly into the router to do any configurations. Yes its been factory reset several times. I also use the default DCHP address.
I truly believe this device has some bad internal parts, my previous nighthawk R8000 worked fine but this device has been extremely troublesome. I also stated all those features are disabled such as circle, parental controls, armor, etc.
