items
Jan 25, 2021Aspirant
Guest network with Access point
Hi My question is a bout setting up guest network while in AP mode. I understand that AP mode is just passs through but any ideas if possible? I have a main router and the RAX80 is connected to it...
antinode
Jan 25, 2021Guru
> possible?
The following router features are not available (grayed out) when
the router is in AP mode:
o Guest Network
On these routers, a "guest" network is not a separate network, but
there are firewall-like rules (enabled by default) which can limit the
ability of "guest" client devices to communicate with non-guest client
devices. (Those firewall-like rules are implemented in the router
section of the device, which is why that functionality is lost when the
router is configured as a wireless access point.)
> is it possible to define any kind of a VLAN on the RAX80 in AP mode
> that will seperate between the main network and the Guest nework?
I'm unaware of any such thing.
- itemsJan 25, 2021Aspirant
Thanks
