gblss
Jan 13, 2021Aspirant
Guest vs. Primary Wireless
Hello, I have the above mentioned router set up with wired and wireless connections. New router current firmware. I have an microsoft surface on windows 10 that connects and works fine using the 5g...
michaelkenward
Jan 14, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
