gblss
Jan 13, 2021Aspirant
Guest vs. Primary Wireless
Hello, I have the above mentioned router set up with wired and wireless connections. New router current firmware. I have an microsoft surface on windows 10 that connects and works fine using the 5g...
gblss
Jan 18, 2021Aspirant
Is anyone going to reply on this. Brand new router no help?
Newfiedrool
Jan 18, 2021Virtuoso
What bandwidth are you using on the 5Ghz channel?
- gblssJan 18, 2021Aspirant
Thank you for your response.
I am using channel 153 and mode up to 4803 Mbps 80MHz (11ax, HT80, 1024-qam). Attached is a screen shot of this setup.
I hope this answers yor question.
Thank you again for your reply.
