Shir
Mar 09, 2021Aspirant
Had issues with my RAX80, so under warranty I replaced my defective unit.
Hello, I purchased a RAX80 Nighthawk router after my previous R7000 went bad. Made the purchase les than a year ago, hoping to get an upgrade from the R7000. The RAX80 had vastly underperformed and ...
michaelkenward
Mar 10, 2021Guru - Experienced User
Do you have a problem that needs fixing?
If so, you have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
