isaaccoo
Oct 09, 2022Star
Had this with the RAXE450 and worked with ProSupport for hours on end, for days, with no luck
I'm gonna piggy back off this thread, as I'm having similar issues.
Had this with the RAXE450 and worked with ProSupport for hours on end, for days, with no luck.
I eventually returned it...
Oct 10, 2022Guru - Experienced User
The RAX450/RAX500 are pretty much the same thing. Netgear is knowns for selling a "slightly" lower spec device to costco so they can sell it cheaper. But hardware wise, they're basically the same. See the R7960P and R8000P
One thing I ran into with my RAX200 was that it would occasionally have issues with 500+mbps speeds. I worked with engineering quite a bit on it and would only ever be told "it must be something with my setup". I never did find a resolution with current firmware for it so pulled my RAX out of service for a different netgear router. Some of the older firmwares worked fine while the newer ones broke it.
One thing to try though that i didn't see was to go XB8 modem/router---->RAXE (in access point mode).
See what speeds that gives. With the 500-600mbps that you're getting, it makes me curious if the RAXE isn't doing some traffic inspection.
Also, check what your link speed is on the device you're testing. I'm curious what link speed its connecting at as actual throughput tends to be around 55-65% of link speed.
isaaccoo
Oct 10, 2022Star
You're right on the money about the Netgear tweaking the same routers to produce different variants - either one was optimized or the other was tuned down. My original move was to get a replacement for the RAXE450 but, Costo doesn't have anymore RAXE450 routers in stock, not do they have any shipments scheduled.
Unfortunately, I got hasty and dropped off the XB8,already. This is my last attempt at making a RAXE work, so I'll probab7y bag one this coming weekend.
Both of the adapters are running at 5Ghz band, and the link speeds are:
KIller AX1650s: 2402/2402 Mbps (throughput at 55-65% = 1321-1561 Mbps)
Netgear AC1900: 54/1300 Mbps (throughput at 55-65% = 715-845 Mbps) - I'm assuming the receive speed @54Mbps may be a bug.
I have QoS disabled, so not sure if any other traffic monitoring is going on.
I see you have the same modem and router. What speeds are you getting on your RAXE500?
- plemansOct 10, 2022Guru - Experienced User
My RAXE and RBKE get around that 1200mbps over 5ghz/6ghz, if I'm close enough/good link speeds. Definitely drops with distance/obstructions.
Thats on 2x different devices running AX210 cards on windows 11. (lenovo yoga 6 and a custom ryzen 2700)
Makes me curious if its something related to the killer's setup as they have their own optimizations.
Can you run that card off stock intel drivers or do you have to use killers?
- isaaccooOct 10, 2022Star
I looked into this before with Dell Business ProSupport, and they had some valid points - like how am I getting over 1400 Mbps over the Xfinity router and my neighbor's TP-Link.
I ventured into upgrading the Wi-Fi card, just in case, and turns out that Dell casually soldered the Killer onto the motherboard.
With the RAXE500, I also bought the A7000, to try to take the Killer Wireless card out of the equation. Netgear Support team also recommended the A7000 to get the 1Gbps+ speeds. And as we can see, the A7000 was a bigger disaster. Both Netgear products, from the same Nighthawk line, but worse performance.
So, in theory, the lowest common denominator seems to be the RAXE500. I'm assuming its something in the settings, because so many others, like yourself, are able to hit much better speeds - from further away.
What settings do have you applied on your RAXE500? Maybe I can replicate those similar settings (but in router mode) and fix this things.
Nothing special on my raxe500. Stock 5ghz/6ghz settings. I move than channels around once in a while just to test but nothing impacts speeds a whole lot in my area. I have access control, traffic monitoring, parental controls, armor/circle, etc all disabled.
I'm surprised to that you're hitting 1500 on the xfi box. Reason why is comcasts standard 1.2gig speed is over provisioned to 1.4 gig, not 1.5gig. What actual speeds do you pay them for?
And to get that speeds from your neighbors is a bit funky too. When I'm 1 room away from my router, it drops from that 1gig plus to 600-700mbps. 5/6ghz drops quickly in speed.
Do you have a different device you can test ?
kind of ignoring the A7000. I've never been impressed with usb based devices and speeds are so variable on them. I've always just taken my laptop/devices apart to upgrade wireless cards.
Also, I'd stick with the xfinity speedtest site. It used to be the ookla test was the best but I've found their servers to sometimes be unreliable. Especially if you're over 1 gig speeds. But even the xfinity one will struggle sometimes with me. I can hit 1 gig plus speeds on 1 test and then 5 minutes later be slower. That's even been applicable with hardwired tests in my area.
NOT saying thats the issue. Just that things aren't as black/white when you're getting to those 1 gig plus speeds in my experience.
