dnm1213_
Jun 10, 2020Aspirant
Hardwire Bridge mode for two RAX120
I have a fairly large house and instead oand purchased another RAX120. I have a hardwired connection going to the router but it seems the bridge mode is only avliable using wireless. Anyway of config...
dnm1213_
Jun 13, 2020Aspirant
Already tried this, that doesn’t help me, because I would need to make the SSID the same on the new router and the device seems to hold to the weak signal from the other AP and switching to the new one. That’s why I wanted to do bridge mode hard wired, because the current bridge mode is only available in wireless mode.
schumaku
Jun 13, 2020Guru - Experienced User
The documented bridge mode does make - in my understanding - the second RAX120 a wireless client to allow the wired (only!) devices over wireless to the primary RAX120. Unless I'm wrong, there is no concurrent Wireless Access Point mode available.
Wireless Access Point is a bridge Ethernet <-> WiFi. You should be able to configure any SSID on the second device as you want. Or does Netgear still refuse putting up SmartConnect with the same SSID on the 2.4 and 5 GHz radios in AP mode?
Last but not least, I have no idea if this config does make a Mesh (supporting the essential 802.11r and 802.11v features) in AP and router mode.
- schumakuJun 13, 2020Guru - Experienced User
The set-up for the wireless bridge in the fine Nighthawk AX12 12-Stream AX6000 WiFi Router RAX120 User Manual p.86ff. "Set Up the Router in Bridge Mode" does vaguely decribe it...
Tihs KB entry (different router, about the same wording) https://kb.netgear.com/25599/How-do-I-set-up-my-Nighthawk-X4-to-Bridge-mode does make it much clearer in my opinion.
