ArunGupta
Sep 15, 2019Apprentice
Has Netgear removed firmware 1.0.1.90?
I do not see firmware 1.0.1.90 for download for RAX120. Has Netgear removed it? All I see is 1.0.0.84. Thanks, Arun
ArunGupta
Sep 17, 2019Apprentice
No thanks, I will pass. Stability is extremely important to me. All my security cameras and alarm system and TVs and phones and laptops are connected via WiFi. In one year, typically 50TB of WiFi data passes through the router. Cannot have instability. 1.0.1.90 was really bad firmware. Glad that it was removed.
avtella
Sep 17, 2019Prodigy
If stability is key, unfortunately probably not best to get a new model (regardless of brand) so soon after release especially with a new WiFi standard that’s only now getting a final draft specification, so not everything maybe supported in earlier draft version based devices like this one. To top it off it takes a while for firmware to stabilize as some of the issues also need to be fixed by the actual chipset manufacturers themselves. Basically early adopters are paying to be testers.
- abogrhenSep 17, 2019Guide
for me i am always a beta tester for everything i will take some bugs just to get the latest futures
and if i see any bugs i just report them
