ArunGupta
Sep 15, 2019Apprentice
Has Netgear removed firmware 1.0.1.90?
I do not see firmware 1.0.1.90 for download for RAX120. Has Netgear removed it? All I see is 1.0.0.84. Thanks, Arun
abogrhen
Sep 17, 2019Guide
i notices the same
should we downgrade or should we wait for an update
as i am not happy with 1.0.1.90
is there any new beta we can try
as i am having problems with intel ax200 card
hikeforpics
Sep 19, 2019Aspirant
I was having problems with the AX200 with 1.0.1.90 as well. The speed would randomly go to a crawl. Disconnecting and reconnecting fixed it for another random period of time.
In looking for a revised firmware I too found 1.0.1.90 was gone. I downgraded to 1.0.0.84 and my AX200 random speed drop problem has been fixed.
Up until I upgraded my client to an AX200 this firmware was working fine as far as I could tell.
I also tried the Killer ax1650 card with the same symptoms with the 1.0.1.90 firmware.
