blue13x
Jan 17, 2020Tutor
Has or will the RAX200 get the final WIFI 6 specs
Hi. I have been using the Netgear routers for some time now and looking into the getting the RAX200. I am aware that the final WIFI 6 specs has been finalized just recently. Is or will the RAX200 ...
avtella
Jan 17, 2020Prodigy
The RAX120 qualitatively uses a superior chipset (Qualcomm), in SmallNetbuilder’s testing the RAX120 did the best in 5Ghz performance testing while the Broadcom chipset based router’s like the chipset in the RAX80/200 saw a weird dip in performance plots.
The RAX200 is basically a RAX80 with an extra 5Ghz band and 2.5 Gb with port but the main Broadcom WiFi chipset and CPU are the same.
Qualcomm usually has a better track record of implementation of new features in a properly working manner. Broadcom still has issues with things like MU-MIMO performance.
- avtellaJan 17, 2020ProdigyBut yeah none of the current routers support all AX features..... Even if chipset vendors promise support later on via an update for current devices I’d be weary. As mentioned previously at least with Broadcom newly added features aren’t necessarily activated in a properly functioning manner, more like just to check boxes. Qualcomm had declared that the QCA8074/8 chipset in the RAX120 supports all the draft AX features but things like uplink MU are missing, though downlink MU is enabled.
- avtellaJan 17, 2020ProdigyIf you want a full featured AX router, I’d hold off right now.
- blue13xJan 17, 2020TutorThat still doesnt the answer of wifi 6 certification
- blue13xJan 17, 2020TutorSo basically there is a chance things wont be supported. Better wait for v2
- avtellaJan 17, 2020ProdigyYep. I’m pretty certain current routers they won’t support all the features even at a later point. But as I said earlier don’t take even the WiFi 6 certification to necessarily mean that all those features will actually work well/cause issues in the first gen chipsets if any even manage to get fully certified in the first place.
