blue13x
Jan 17, 2020Tutor
Has or will the RAX200 get the final WIFI 6 specs
Hi. I have been using the Netgear routers for some time now and looking into the getting the RAX200. I am aware that the final WIFI 6 specs has been finalized just recently. Is or will the RAX200 ...
blue13x
Jan 17, 2020Tutor
That still doesnt the answer of wifi 6 certification
blue13x
Jan 17, 2020Tutor
So basically there is a chance things wont be supported. Better wait for v2
- avtellaJan 17, 2020ProdigyYep. I’m pretty certain current routers they won’t support all the features even at a later point. But as I said earlier don’t take even the WiFi 6 certification to necessarily mean that all those features will actually work well/cause issues in the first gen chipsets if any even manage to get fully certified in the first place.
- digitsnbitsJan 19, 2020Apprentice
There are quite a few Wifi6 certified routers now. Unfortunately none of them are made by
Netgear. The Asus RT-AX88U is WiFi 6 certified and it uses the Broadcom chipset.
Ever wonder why Netgear is absent from that list? Probably because their firmware side of all their wifi6 products are a complete disaster and the absolute stonewalling of acknowledgment of any existing problems.
- blue13xJan 19, 2020TutorI'm starting to believe that asus is the way to go. So far had good experience with netgear. Also the the netgear AX nighthawk routers look great.
