JKonman
Aug 27, 2020Aspirant
HDD not showing
Have a Seagate 10tb hdd hooked upto my router I have readycloud setup and installed but the HDD isnt showing and I've tried the readycloud app on my phone and on windows and no use I have all the lat...
schumaku
Aug 28, 2020Guru - Experienced User
Common problem are existing file systems on external USB storage devices. On larger capacity, a common default is exFAT these days - but that won't be recognized on the Netgear routers.
Re-format e.g. to NTFS while connected to a PC.
JKonman
Aug 29, 2020Aspirant
File System is already NTFS whats adding to it may be my readycloud isnt connecting to my rounter it keeps saying that it's offline when i try to connect with it.
