Adam_Toronto
Feb 23, 2020Follower
Heat Handling RAX80
I am finding the RAX80 doesn't handle heat well, and performance is degraded if it is not particularly well ventilated. I purchased a second version of the same model to be sure, and the issue remai...
schumaku
Feb 23, 2020Guru - Experienced User
Christian_R several RAX customers have asked if there is a way to read the values of the internal temperature(s), the fan status, ... Few reports say the an is always on, but several users state the RAX, especially the RAX80, is running very warm. Wonder on how Netgear's support is checking these devices are running within specs if there is no (hidden) Web UI showing the details required?
Adam_Toronto either way, these consumer devices are designed to be operated in an open space (not in an enclosure, box, ...) as per the Nighthawk AX8 8-Stream AX6000 WiFi Router Model RAX80 User Manual
Operating temperature 0° to 40°C (32º to 104ºF)
Operating humidity 90% maximum relative humidity, noncondensing
