todd1010
Jan 05, 2020Apprentice
Help a dummy understand the built in VPN feature on my AX12 RAX120.
I've got my router setup and has been running great for several months now. I'm considering using the built in VPN feature. I was going to try another brand but it appears its not one that works with...
Christian_R
Jan 07, 2020NETGEAR Employee Retired
Hi todd1010,
1. The following link should answer your first question as you will need to install the OpenVPN client/app.
https://kb.netgear.com/29783/How-do-I-use-VPN-service-on-my-Nighthawk-router-with-my-Android-device
2. The VPN service should not hinder the performance of your connected devices.
Christian
