schlagdog
Apr 21, 2019Tutor
Help all in one computer not recognizing nighthawk rax40
hello, we replaced our router and is setup, all devices such as cell phones, tablets and another computer are all connected via wi-fi except mine. My computer will not recognize the router and its in...
schumaku
Apr 23, 2019Guru - Experienced User
schlagdog wrote:
Is there a download software update on this site for this router.
https://netgear.com/support type yourmodel umber, like RAX40, and select it - you get https://www.netgear.com/support/product/RAX40.aspx ...already two updates the last two days.
Ref your own computer pleae provide a little bit more information. In the same room, location allowing, better use a network cable anyway.
