Soap90
Feb 13, 2024Aspirant
Help looking for compatible power adapter but with longer cable for Nighthawk AX5400
I'm trying to find a power adapter for this specific model but with a much longer cable. The room that I want to move the router to has an outlet that turns off from a switch on the wall so I don't w...
Soap90
I won't be able to use that unfortunately. I currently have the router connected to a surge protector, which is why I wanted to see if there was an adapter but that comes with a much longer cord length.
Feb 13, 2024Guru - Experienced User
Then get a extension cord that will plug in to the surge protector. They come in many length, colors and can be connected to any wall outlet or surge protector, etc.
