Soap90
Feb 13, 2024Aspirant
Help looking for compatible power adapter but with longer cable for Nighthawk AX5400
I'm trying to find a power adapter for this specific model but with a much longer cable. The room that I want to move the router to has an outlet that turns off from a switch on the wall so I don't w...
Feb 13, 2024Guru - Experienced User
you can also get 12v power extensions. I've seen them on amazon. but you have to be careful as you're going to get power drop with using an extension on the 12v side if you go to far.
You won't have to worry about any power drop on the 110v power side of the adapter by putting an extension cable here to the wall outlet or surge protector.
