HornsManiac
Nov 09, 2022Aspirant
HELP my model RAX50 is only broadcasting guest network
This morning the only network I see is the Guest one. I already rebooted my modem and router, and that didn't help. The problem is I cannot access the router online because I can't connect to it. I w...
- Nov 09, 2022
Seems last night, there was a bug with the latest update with the RAX50 where for some users, it failed to retain all of the changed settings. While it is annoying with rare issues like this, it is best to do a factory reset and do a setup from scratch without using a backup config file.
Razor512
Nov 09, 2022Prodigy
HornsManiac
Thank you for the help!
