Tinkerbell666
Mar 07, 2021Aspirant
Help needed
Hi all, I'm new here and looking for something help please. I apologise in advance if this is posted in the wrong place. I have BT fibre 900. I want to change my BT router to a netgear in the hope I...
Tinkerbell666
Mar 08, 2021Aspirant
Hi there,
Thank you for your reply. My house is about 170 years old. So Full of concrete and brick.
Mar 08, 2021Guru - Experienced User
Ouch.
2 of the best blockers of wifi.
Many who end up in situations like yours end up using a mesh system with a wired backhaul. That wired backhaul could be using moca adapters, powerline, or ethernet.
- Tinkerbell666Mar 08, 2021AspirantThanks for your reply again. Tell me about it. You goto love concrete. I'm really sorry but you lost me at mesh. I'm not very tech savy on this kind of stuff.
With my Bt I've got the bt wifi disc upstairs which is not to bad. Items tend to loose the connectivity and Internet which is why I'm looking into something that offers a stronger WiFi. From what I've read some netgear offer WiFi 6 (I think) so really just looking at options that won't break the bank.- Tinkerbell666Mar 08, 2021AspirantI was looking at something the Nighthawk pro XR1000. From what I read it seems to offer good WiFi range.
- plemansMar 08, 2021Guru - Experienced User
wifi 6 didn't increase signal strength, it just made the weak signal a little more efficient.
A mesh system is something that uses multiple access points (satellites) to pickup and rebroadcast a signal.
with the concrete/brick I'd recommend either using a triband system like orbi or using a dual band with the wired backhaul.
- Tinkerbell666Mar 08, 2021AspirantThank you for your help. I really appreciate it. Its time for me to do some in depth research and understand more of what I need to do. Thank.you again.
