akchcirn37
May 04, 2022Follower
Help Reflashing RAX45 Over TTL - No Reset Button, No Ethernet Ports
Need some technical advice here, please! Need advice on how to flash or reset the RAX45 using a TTL to serial connection. Background... - The latest firmware for the RAX45 (1.0.10) bricked my rout...
May 05, 2022Guru - Experienced User
Sounds like the router is just dead. Something to contact NG support and see what your options are:
