Th3-0n3
May 26, 2020Tutor
Help router keeps loosing connection, slow speed, stop giving access to internet.
Ok so I have a Nighthawk® AX12 RAX120 ever since I updated to the most recent version that is V1.0.1.122. After the update I decded to do a factory reset on the router. I started to have this pr...
RajaDaja
May 26, 2020Luminary
I hear you!
Look, it happens to me also, but not as frequently, maybe a couple times a week. Hopefully the kinks will get worked out through firmware updates. But your case..........2-3 times a day, warranty? Call support get them to troubleshoot , maybe they will replace. Good luck!
- Th3-0n3May 26, 2020Tutor
yes its been really bad this last three days but today its been worse. after taking this last update this happen. I will contact them I bought it on december 20 or by them it should be in warranty i guess.
RajaDaja wrote:I hear you!
