Morgenk
Sep 16, 2023Aspirant
Help with bridge?
I have a Cox cable modem/WiFi. I have the Rax router connected to the modem. It functions as router. The cable modem has the WiFi bands turned off. My PC is connected directly to the modem. My problem...
michaelkenward
Sep 16, 2023Guru - Experienced User
This does not disable the router side of the cable modem router.
