Morgenk
Sep 16, 2023Aspirant
Help with bridge?
I have a Cox cable modem/WiFi. I have the Rax router connected to the modem. It functions as router. The cable modem has the WiFi bands turned off. My PC is connected directly to the modem. My problem...
Morgenk
Thank you very much for taking the time to reply. I don't think I need to tell you switching to an AP solved my issue, and headaches. Thank you again very much for your advice.
