Morgenk
Sep 16, 2023Aspirant
Help with bridge?
I have a Cox cable modem/WiFi. I have the Rax router connected to the modem. It functions as router. The cable modem has the WiFi bands turned off. My PC is connected directly to the modem. My problem...
Morgenk
Thank you very much for taking the time to reply. I don't think I need to tell you switching to an AP solved my issue, and headaches. Thank you again very much for your advice.
Sep 16, 2023Guru - Experienced User
Something to try next time if you want the RAX router to run behind another router while in router mode, use the host routers DMZ for the 2nd router behind. This usually help with the double nat issuse.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
