jmsquared141's avatar
jmsquared141
Follower
Jul 23, 2019
Help with buying decision NETGEAR Nighthawk AX12 12-Stream WiFi 6 Router (RAX120) - AX6000 Wireless
I have a Nighthawk X10 AD7200 Model R9000 and am wondering if I would gain a performance upgrade with the AX12?
  • you won't at the moment. I'd also advice not to buy any WiFi-6 routers like the RAX120 as these are based on a specification which is still a draft and not finalized. If I was you, I'd wait a year and a half or longer for everything to settle down (firmware & hardware). I'm sure NG will release another WiFi-6 model when the draft is finalized or upgrade current models (v2, v3, etc) to comply
  • michaelkenward's avatar
    michaelkenward
    What issues do you have with the R9000?
    Anything running slow? There might be ways of fixing that without denting your wallet.
