Erinpiper
Jan 05, 2022Star
Help with New Router
Hello, HELP. I think it's time to upgrade from my old WNDR3400V3 router. Should I consider a new router? I think I have 10 or so devices to connect. I have a small home 1400sq ft and co...
- Jan 05, 2022
Erinpiper wrote:
Are those options compatible with the new Nighthawk app? Is the app something to consider when looking at these new routers?
Will Netgear honor the renewed router as if it were new and does Netgear do the renew on the unit? I have never tried anything that was renewed?
Thank You
Renewed warranties are shorter as well as the support period is less. But even if you factor in an aftermarket warranty through amazon, its still far cheaper. And its just a thought. If its concerning and you'd like a longer support period, then go with a new device. but you'll end up with a lower spec device for the same price.
In terms of 6E, its not really in the budget for what you're plans are. And I'm not a huge fan of it yet as there really isn't much for 6e devices and its range is much shorter than 2.4ghz/5ghz.
With the devices you have, a decent dual band router should be more than enough. Tribands are nice when you get a lot of devices streaming at once. Your internet connection will bottleneck before the router will with what you're current speeds are.
And I'd certainly recommend making sure you have at least gigabit. 100mbps might be your speeds now, but a lot of the isp's have been setting their base speeds at that 200mbps speeds.
Jan 05, 2022Guru - Experienced User
Amazon has a renewed RAX75 (AX5700) for around that $150. pretty cheap as new its around 300.
Or you can go with a solid AC router like the R7800.
There's other ones you can look at and peruse.
Erinpiper
Jan 05, 2022Star
Thank You
- plemansJan 05, 2022Guru - Experienced User
Thank You
- ErinpiperJan 14, 2022StarTook your suggestion and found a renewed RAX80 router for $200 with 2 year warranty. Will post on ease of install and how it works.
Thank You- FURRYe38Jan 14, 2022Guru - Experienced User
- ErinpiperJan 05, 2022Star
Thank You to everyone who responded with help, suggestions and links. Looks like I have some research to do to narrow down all your great suggetions. I will search the Netgear site for your suggestions and try to figure out my best options.
I appreciate all your help and giving me a direction to go in to find the best one for my needs.
Erinpiper
Would the tri-band ax8 8 stream ax6200 wifi6 rax78 be something to consider or is it more than I need, for another $65?
With a new router like this, will it require a new modem or will my current modem be sufficient? It seems to work well with my current router and was supplied by the isp.
I just checked the Netgear website for the router you mentioned, the rax75. Seems that they don't sell that router online from Netgear anymore, they take you to an outside retailer. Is this a common practice for Netgear? Seems like it is a fairly new router that they no longer sell themselves. Just struck me a bit odd.
