NightHawkAX6
Aug 19, 2020Follower
Help with NightHawk AX6 (AX4300)
Just purchased NightHawk AX6 (AX4300) from Costco. Anyone may help on how to set it up. Do I still need the old crabby router. I installed the app on my iPhone. it shows I am connected to the we...
Aug 20, 2020Guru - Experienced User
AX4300 is a speed, not a model. which model did you buy?
What modem is it connected to?
If you go to netgear.com/support/ type in your model number and it'll take you to the support site for your device.
If you just bought it, you also have the option of the 90 days of support for new devices. Click on "mynetgear" at the top. Register an account and the device. From there you can contact support for help with setup.
