JL916
Mar 23, 2021Aspirant
Help with RAX78 in bridge mode
Hi, I just recently purchased AX8 Nighthawk router and I am having some issues configuring router in bridge mode. Here's a little background on my current setup. I live in a rural part of town ...
- Mar 24, 2021
You could try a wireless repeater.
Or there's been a few posts on reddit about making that hotspot work with routers.
Inseego Mifi 8000 USB HUB / ethernet / router connection possible? : Calyx (reddit.com)
JL916
Mar 24, 2021Aspirant
Thanks for the response Plemans. I have the Inseego Mifi 8000 and it does not have an ethernet port, just a USB-C port that it uses for a power supply. It's starting to seem that the RAX will not work out in my setup.
Mar 24, 2021Guru - Experienced User
- JL916Mar 24, 2021Aspirant
I saw the post earlier and was hoping that the AX would work for me, but I think I will follow the suggestions from the folks on the Reddit thread and use the same setup they used. Thanks again!
