designgrrl's avatar
designgrrl
Help with USB Device and ReadySHARE on RAX30
Hello helpful souls,   I am trying to attach a LaCie d2 Professional 8TB External Hard Drive to the USB port of my Nighthawk AX2400 RAX 30. (Links are to Amazon and will open in a new page.)   Fo...
  • michaelkenward's avatar
    michaelkenward
    Jan 23, 2022
    designgrrl wrote:
    Could you tell me which 8TB Seagate drive you're using? Right now, I think I'd rather purchase something with at least one example of proven success than bang my head against the wall trying to get the LaCie to work.
    Seagate Backup Plus Hub 8TB. STEL8000200.
    This is in an R7800. It does not claim to be compatible with that router. It just works. I got it because it is listed as working with the R7000P. I have one of those too.
    But this is suspicious:
    So I decided to a 1TB Seagate Expansion Portable drive that I had lying around, since you mentioned success with Seagate. This showed promise, because I was able to use the "Create Network Folder" GUI. However, I still bumped. up against that ~200mb-sized "S_Drive" issue that I had with the LaCie.
    Is that what you got on the Mac? If so, it smells like something that has nothing to do with ReadySHARE.
    You might want to see what they say over on the RAX world.
