dkenniston
Jan 22, 2022Aspirant
Help with VPN DDNS Port Forwarding Setup
I'm not a tech guru, but am trying to set up my VPN. First step was setting up a No-IP account for DDNS. That is done. No-IP instructions recommended Port Forwarding as part of setup. Not sure what...
Razor512
Jan 24, 2022Prodigy
With the VPN service on netgear routers, there is no need to do any port formwarding asthe router will automatically configure things for you.
If you use DDNS just be sure to set that up first, and when the router is able to successfully update the DDNS entry. then on the VPN page
the only settings you need to worry about is whether you want to allos VPN clients to access just the LAN or if you want them to also access the internet through the VPN.
Their instructions for Mac OS, lead here. https://openvpn.net/vpn-server-resources/connecting-to-access-server-with-macos/
They list instructions for multiple different clients
You will likely need to unzip the config file since it needs to access the .ovpn file.
This video should help provide more info on how to do it. https://www.youtube.com/watch?v=j2ZMLFMsq3c
