Jipinp
Sep 01, 2023Aspirant
High latency
Hi am facing high latency in gaming . More than the original router. Is there anyway to reduce it please help ..
Sep 01, 2023Guru - Experienced User
What model NG router do you have?
What gaming device are you using?
Wireless or wired for gaming?
Jipinp
Mine is rax80 ax6000
I live in uk my internet provider is virgin media
1 gbs download and 100 mbps upload I use iPad to play Pubg mobile I have a tp link ax1500 I get latency of 12ms but when I connect on nighthawk I have latency of 30 ms and experiencing high lag
- FURRYe38Sep 03, 2023Guru - Experienced User
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Some Virgin Media have routers built in to there modems. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first... - michaelkenwardSep 04, 2023Guru - Experienced User
Jipinp wrote:
I live in uk my internet provider is virgin mediaThat usually means a modem/router.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Jipinp wrote:
I have a tp link ax1500That's not a model number. TP-link makes various devices with that label, which is no more than a wifi speed indicator.
