Jipinp
Sep 01, 2023Aspirant
High latency
Hi am facing high latency in gaming . More than the original router. Is there anyway to reduce it please help ..
Jipinp
Mine is rax80 ax6000
I live in uk my internet provider is virgin media
1 gbs download and 100 mbps upload I use iPad to play Pubg mobile I have a tp link ax1500 I get latency of 12ms but when I connect on nighthawk I have latency of 30 ms and experiencing high lag
Sep 03, 2023Guru - Experienced User
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Some Virgin Media have routers built in to there modems. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
