Fasteddie3g3
Oct 24, 2022Aspirant
Home surveillance cameras in DMZ keep received Network Attacked Blocked warnings (RAX-200)
RAX-200 Nighthawk Router with latest firmware 1.0.10.140 and I have a home surveillance cameras system must put in DMZ in order to work with remote web checking and monitoring I kept received Networ...
Oct 25, 2022Guru - Experienced User
Why does it need the dmz to work? What issues/what actually happens?
What modem/gateway is the router connected to?
- Fasteddie3g3Oct 25, 2022AspirantEver since I started using RAC-200 router assign IP address as previously but I can’t get it to work and the surveillance system installer said it might be newer type of router with its security therefore he configured assigned IP address to DMZ and mobile monitor app and web access both working so it remains till now
- michaelkenwardOct 25, 2022Guru - Experienced User
Fasteddie3g3 wrote:
Ever since I started using RAC-200 router assign IP address as previously but I can’t get it to work ....If you need the spy system to stick with its IP address, it can be easier to set it on the surveillance system rather than the router. Of course, that depends on the system supporting that option.
- Fasteddie3g3Oct 25, 2022AspirantNo it is just 4 sets of IP still cameras hook up to a HDD recorder on premises for security purposes
- Fasteddie3g3Oct 25, 2022AspirantSorry, it is connected to fiber optic modem
- plemansOct 25, 2022Guru - Experienced User
What fibre optic modem is it connected to?
it still shouldn't need to be in a dmz unless there's some other issue causing it to need that- Fasteddie3g3Oct 25, 2022AspirantI am puzzled as well, I have tried remove it out of DMZ and whole surveillance system in-reachable, I have no other solution
