Fasteddie3g3
Oct 24, 2022Aspirant
Home surveillance cameras in DMZ keep received Network Attacked Blocked warnings (RAX-200)
RAX-200 Nighthawk Router with latest firmware 1.0.10.140 and I have a home surveillance cameras system must put in DMZ in order to work with remote web checking and monitoring I kept received Networ...
Oct 25, 2022Guru - Experienced User
Why does it need the dmz to work? What issues/what actually happens?
What modem/gateway is the router connected to?
Fasteddie3g3
Oct 25, 2022Aspirant
Sorry, it is connected to fiber optic modem
- plemansOct 25, 2022Guru - Experienced User
What fibre optic modem is it connected to?
it still shouldn't need to be in a dmz unless there's some other issue causing it to need that- Fasteddie3g3Oct 25, 2022AspirantI am puzzled as well, I have tried remove it out of DMZ and whole surveillance system in-reachable, I have no other solution
Still don't know what modem/gateway its all connected to
